Engine overheated on hose with salt terminator attatched
Results 1 to 8 of 8
    Jul 2009
    nc
    I just got my ski running good, rode on the river yesterday and hosed it all off with salt terminator connected and hooked it up to flush and it overheated, I gave it about 40 to 50 seconds to start peeing, water was coming out exhaust but not alot and was reaching to shut it off and it cut off and started beeping overheated. So I let it cool down and pulled the salt terminator and hooked hose up and flushed it with no problem so I guess I need to figure out a way to increase water flow on the salt terminator adapter? It does flow less water than just the hose. Anyone had this problem?
    Banjomaniac
    Top Dog west_coaster's Avatar
    Apr 2005
    San Diego CA
    Re: Engine overheated on hose with salt terminator attatched
    Mine flows a lot less than the hose, but I just keep turning the water on harder until I get a good stream out the pisser. The salt thing only has a 3/8" hole and the garden hose is 1/2".
    05 F-12X
    Jul 2009
    nc
    Thanks West coaster, I turned the water full blast but still only a little coming out with the sprayer. I might drill the hole a little bigger. I rode for about 20 minutes today and it seemed fine. I see you got your ski going, did you get a new exhaust manifold?
    Banjomaniac
    Jul 2009
    nc
    It was windy and choppy and I almost lost it a couple times, couldn't go full throttle very long it was ROUGH!
    Apr 2005
    San Diego CA
    Is the water slow only when you add the salt away dispenser? It's fine when you just use the hose?
    Yeah, my ski is back up running. I found a used fresh water manifold, looked like brand new inside. I went out in the ocean today and it runs like brand new. Still thinking I want a newer ski with more HP.
    05 F-12X
    Jul 2009
    nc
    I want one with less HP, I'm to old to fall off this thing running 60mph. It's like a rocket. I can't imagine one with more power.
    Apr 2005
    San Diego CA
    Quote Originally Posted by banjomaniac View Post
    Your only as old as you feel. I have the body of a 20 year old. (In the trunk of my car)
    05 F-12X
    Jul 2009
    nc
    LMAO! Here is a ski I saw for sale, crazy!...s-l500-2.jpgs-l500-1.jpgs-l500.jpg
