Results 11 to 15 of 15
    Jul 2014
    AZ
    Re: MacsBoost 2006 F12X Review!
    Ahh, ok. However, I would be careful plugging holes (which a quick connect may do, when on the lake) the oem doesn't suggest. I just shove a piece of tight fitting hose over the nipple when flushing or running in the driveway. Easy peasy. No need for fancy stuff.
    Jul 2014
    AZ
    Typically a "quick connect" will not flow when not connected so running a quick connect while on the lake may impede flow that is intended in the oem design. Personally I would shy away from that but who am I... I'm no genius or guru. Just kind of an experience and common sense sort of thing.
    Jun 2016
    Newport
    In the the heat of the summer the only thing that I have seen make any true difference is pump octane.
    Jun 2013
    Richmond, Virginia
    For my conditions, my ski will overspeed tow or three times when started at full throttle at idle speed. Yes, my F-12X does cavitate more with 205 hp. Most say to go with another impeller, but I was OK with stock. I run the 17.5 boost plug with 93 octane pump gas as recommended by Mac.
    Chris
    Quote Originally Posted by trxxx250r View Post
    Chris, did you notice any significant pump cavitation after you gained horsepower from the macsboost kit? I certainly did and will be looking into the best way to deal with it. It's very evident in this video I made riding it. I had some cavitation issues when it was stock with the stock impeller but when I went to the solas prop it totally cleaned that up. Then, with the macsboost at 19 lbs. boost it is back in a big way...
    https://www.youtube.com/watch?v=__AbyHazrBU&t=13s
    2017 Yamaha GP 1800 (Riva stage one re-flash and intake, Candoo Pro GPS)
    2007 Honda F-12X GPScape w/ MACSBoost Plug-in Module and Intercooler
    2013 Cobalt 232 w/ 350 Mag and Bravo 3
    Jul 2017
    High rock lake nc
    My ski was suffering from heat soak. I installed a water meth injection kit 50/50 water meth raises octane to around 110 and it’s cheap basically windshield washer fluid. Cools the intake temp by 100 degrees well worth the money.
