Results 11 to 20 of 20
    Aug 2017
    Vancouver Island, Canada
    Re: dual carb tuning
    Quote Originally Posted by Yabadabadoo View Post
    what are these T fitting adjusters you're talking about? sorry, not trying to hijack but I have the same issue. Thanks
    Never mind, I figured it out... Duh... Lol
    Top Dog hooka-2's Avatar
    Nov 2005
    sebring florida
    next time you rebuild your carbs drill the heads of the adjustment needle screw and install a small roll pin. Cheaper than buying a set. The brass screws drill super easy with a drill press and a small drill bit. Once reassembled the screw can be easily turned with your fingers
    90 X2 (750), 92 X2 (750), 93 X2 (750),93 X2 (750), 99 Ultra 150(sold) 1995 Waveblaster 1
    charlotte,nc
    if you can find t fitting adjusters for the keihins let me know. the sxr carbs are mikunis and t handle adjustment screws are readily available online. however i have not been able to find a set of t handles for the keihin carbs. you might can use a long screwdriver on the idle mixture screw but i have yet to find a way to adjust the high speed screw on the rear carb for dual keihins without taking the carbs off. again im talking about the dual keihins.
    Nov 2005
    sebring florida
    Just make your own. Super easy. Drill the head, install roll pin, done
    Sep 2015
    Northern Michigan
    I actually use a very small thin screw driver. Realize that it requires very little force to turn the screw once your on it. put your left hand behind the carbs and with the right holding the screwdriver position it between the cylinder and the carb. Left hand guides it and the right turns it. Even on the best day it frustrating. But sure beats pulling them.
    Hooka- not sure how you would do what your saying the end of the screw is surrounded by a protective skirt that will not allow you to do what your saying. Perhaps you could post a picture of what you have done.
    Jul 2015
    Huntsville AL
    I use the bit from an interchangable driver set. Lean over from the other side of the ski in order to get the right angle with your fingers.
    Disclaimer: I have been on the bank rocking my ski over to fish the dropped bit out from under the engine plate..
    Sep 2015
    Northern Michigan
    Found these , they are 21.00 each. https://www.alliedleisurecorp.com/pr...oogle.com%252f
    Number 7 appears to be a low speed adjuster screw they dont have the high speed . but its never the problem
    Nov 2005
    sebring florida
    Quote Originally Posted by Hydro-Mike View Post
    You are correct. I forgot I cut those off to expose the t-handles. It doesn't effect anything as far a strength. Makes tuning a breeze
    Sep 2015
    Northern Michigan
    Quote Originally Posted by hooka-2 View Post
    That's what I was thinking. Just a lot of work, but makes it easy from there forward. Good mod for winter
