Results 1 to 10 of 20
    Sep 2017
    Indiana
    dual carb tuning
    Just put my 96sxi back in the water after 15ish years. Tore it down with a fine tooth comb. Starts like new. Runs like new. I almost have the carbs set correctly. It's dual carb and I'm having trouble accessing the screws in between the carbs. Anyone have any secrets?
    Smirk
    PWCToday Newbie RipTide1's Avatar
    Jun 2012
    Wyoming, MI
    Re: dual carb tuning
    Quote Originally Posted by Mr.Smirky View Post
    Smirk
    I was able to get to the screws with a very thin 10" flat blade screw driver. It was on a slight angle but it worked for me
    Sent from my SM-G920V using Tapatalk
    SE MI
    Ditto.
    Yep, long thin flatblade or the $90 pinion gear drive carb screwdriver.
    Sep 2017
    Indiana
    Thank you.. I appreciate the input.
    Top Dog RacerX2's Avatar
    Feb 2010
    Far Away From You
    https://www.amazon.com/Motion-Pro-08.../dp/B000UKD6YC
    cheaper of the two motion pro 90 deg drivers
    See di46 drink......See di46 drive......Don't be a di46......
    Quote Originally Posted by RacerX2 View Post
    I have that one, cant get it in between on keihin racks.
    Mar 2005
    Michigan
    I would take the carbs apart over the winter and put the brass t fitting adjusters in each carb, that's what I'm doing on my 800sxr carbs this winter.
    1997 Seadoo SPX---limited mod
    1996 Seadoo GSX--Cruiser
    Aug 2017
    Vancouver Island, Canada
    Quote Originally Posted by seadoobutch787 View Post
    what are these T fitting adjusters you're talking about? sorry, not trying to hijack but I have the same issue. Thanks
    Sep 2017
    Indiana
    I just rebuilt them in July. I'm not taking them apart anytime soon I went to Harbor Freight and got an assortment of smallish screwdrivers. I found the recommendation for the 10" screwdriver very helpful. You can get it underneath the back carb and it goes in relatively straight. That was the part I had trouble with.. visualizing that I could get the screwdriver underneath.
