Polaris PRO 785 1999 Carbs and fuel info
    Frequent Poster scensor's Avatar
    Jun 2013
    Greece
    Good day to all,
    I am writting on behalf a friend on mine who owns the subject jet ski,
    Here's our problem.
    I am trying to find a fuel diagram see if all the fuel lines are put correct. And i am trying to find carbs specs the factory ones. Low's High's and whats the needles spings and the return fuel jet. Any info or even if anyone knows where i can download a manual for this ski it will be really helpfull.
    Thank you all in advance!
    Aug 2010
    delavan, wi
    Re: Polaris PRO 785 1999 Carbs and fuel info
    For 99, should be the same for all of them.
    90 Superjet, 98 Polaris Pro 785, 95/92 Kawasaki 750 sxi, 01 Polaris 600 sc xp
    Top Dog sea-one's Avatar
    Aug 2011
    Dallas tx
    Keep in mind that Fuel refinement has changed, You can't use original settings on jetting or meter screws settings in my opinion. Fuels use ethanol so you will need more fuel than before, Its a test and tune thing. you'll need several quick WOT runs to check coloration of the spark plugs to ensure your not too lean. just my opinion
    2004 Rxp Stock Motor with other light mods
    1996 Xp Resurrected july 2014/SOLD 2016
    1991 Kawi 750cc Big pin Twin Carb Sport Cruiser Custom (Resurrected Feb 2015 completed June 2015)
    2000 XP Saved Spring 2016- Resurrected July 2016 as new
    2002 Seadoo ISLANDIA/Sold
    CANDoo Pro system
    Jun 2013
    Greece
    2.0 or 2.3 needle. Thanks for the reply ro all
    Frequent Poster jax724's Avatar
    Aug 2011
    Omaha
    sub'd
    #Racegirl623 ~ Alli Kay Partch (my daughter)
    2004 Kawasaki SXR 1100
    2011 Kawasaki SXR Limited
    Bullett 1100 "Sparkles"
    1999 Polaris PRO 785
    1997 Seadoo SPX
    Region 9 2013 Champion - Novice Womens Ski Limited
    2013 World Finals 8th place - Novice Womens Ski Limited
    Region 9 2014 Champion - Novice Womens Ski Limited
    Region 9 2014 Runner-Up - Amateur Ski Open
    Region 9 2014 Runner-Up - Amateur 800 R/A
    2014 World Finals 9th place - Novice Womens Ski Limited
    Facebook Racegirl623
