js550/650 build - Page 2
Results 11 to 20 of 25
Thread: js550/650 build
    Frequent Poster Lake St. Clair Rider's Avatar
    Oct 2015
    Michigan
    1991 550sx stock
    1990js440/550sx coffmans half pipe
    1988js550/650 running/almost done
    1993 SN Superjet factory pipe
    1989 x2 stock
    charlotte,nc
    Re: js550/650 build
    to properly repair the cracks and not have to worry about them coming back or getting worse, youll need to and down the cracked area to get as much of the crack out as possible, then get some epoxy resin and some cloth, add several layers overlapping the entire cracked area by a few inches,then sand down and repaint.
    if that filler you used isnt made for smc, it most likely wont hold. the vintage kawasakis are made of sheet molded compound or SMC and require very clean sanded surface and epoxy based fillers or resins. if the filler you used works with smc then you should be ok.
    Oct 2015
    Michigan
    1991 550sx stock
    1989 x2 stock
    Oct 2015
    Michigan
    Re: js550/650 build
    i used pwc filler, I’ll have to see if it’s made for smc. Thanks
    1991 550sx stock
    1989 x2 stock
    Frequent Poster Sxsixfitty's Avatar
    Nov 2014
    Michigan
    Re: js550/650 build
    Future plans for a similar build so I will be lurking around on this one.....
    Oct 2015
    Michigan
    Re: js550/650 build
    92E642C0-9A7C-4C52-88BE-3319E6C79852.jpegCDAEE55E-896D-43A8-9DF1-3B8F06BC2F23.jpeg483F338B-AA81-4CDB-9000-B3D57D1EC0FD.jpeg09DB7E25-98B5-4A35-A4A9-4F53FBD1BBF5.jpeg224007D1-A4F9-4CCA-BE5D-FF54D45AE090.jpeg Hull is primed and ready for paint. Also got a fiberglass repair kit and layed one layer of fiberglass on the cracks I have. Plan to add one more layer to make sure it’s solid.
    1991 550sx stock
    1989 x2 stock
    Nov 2014
    Michigan
    Re: js550/650 build
    Any details on the motor and paint scheme?
    Oct 2015
    Michigan
    Re: js550/650 build
    Quote Originally Posted by Sxsixfitty View Post
    got a 650 motor with a stock pipe, still need a different carb because I don't want to run the 28mm carb it came with. Got everything needed for the conversion, just need to make a bracket to mount up the 650 electronics. For paint, I'm thinking royal blue on the top deck and maybe some graphics.
    1991 550sx stock
    1989 x2 stock
    Oct 2015
    Michigan
    Re: js550/650 build
    C3240D5F-768F-493E-9E30-50DEA319576F.jpegC3240D5F-768F-493E-9E30-50DEA319576F.jpeg4A1F6DED-C6FB-4962-81EE-4ACCBFAC31C1.jpeg
    Finally got it painted. Now it’s time to clear coat it and put it back together. Looking for a good conversation prop and carb setup. Have parts to trade.
    1991 550sx stock
    1989 x2 stock
    Oct 2015
    Michigan
    Re: js550/650 build
    Got it touched up and ready for clear coat.
    1991 550sx stock
    1989 x2 stock
