js550/650 build
Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: js550/650 build
    Frequent Poster Lake St. Clair Rider's Avatar
    Oct 2015
    Michigan
    js550/650 build
    Bought a 1988 js550 for $240 dollars that needs some love. The engine was full of water so i decided to throw in a 650 I have laying around. I plan to tear everything down and repaint and re-assemble everything. As of right now I need a 550/650 conversion plate, steering cable, am waterbox, 650 pipe and maybe a different pitch prop (unsure on what size works best). Will post pictures along the way. Thanks, Zach
    1991 550sx stock
    1990js440/550sx coffmans half pipe
    1988js550/650 running/almost done
    1993 SN Superjet factory pipe
    1989 x2 stock
    Oct 2015
    Michigan
    1991 550sx stock
    1989 x2 stock
    Oct 2015
    Michigan
    Re: js550/650 build
    1991 550sx stock
    1989 x2 stock
    Oct 2015
    Michigan
    Re: js550/650 build
    IMG_1658.JPGIMG_1659.JPGIMG_1660.JPG Also learned how to sub, so I thought I'd share lol.
    1991 550sx stock
    1989 x2 stock
    Frequent Poster Jetskipunk's Avatar
    Jan 2015
    reno
    Re: js550/650 build
    looks awsome!!
    Sent from my SM-G920P using Tapatalk
    Oct 2015
    Michigan
    Re: js550/650 build
    IMG_1682.JPGIMG_1688.JPGIMG_1689.JPGIMG_1687.JPGIMG_1686.JPG Took all the decal and turf off as well as all the parts. It is now ready to be sanded then painted. Also have a few cracks to patch. What should I use to patch these cracks? 650sx pipe found, still need a prop, waterbox, and steering cable. Lastly, are 650 steering cables the same as a 550?
    1991 550sx stock
    1989 x2 stock
    Resident Guru still standin's Avatar
    Jul 2009
    michigan, KZOO
    Re: js550/650 build
    The Cables are not the same.
    I believe I have most of the parts you need.
    -Conversion plate
    -550 steering cable
    -steep Skat impeller for the conversion
    Send me a PM if interested in working out a deal.
    -92 550sx/750 conversion "sold"
    -94 750sx modded
    -86 X2 - Twin carb 750 swap
    -88 X2 - build in progress
    Oct 2015
    Michigan
    Re: js550/650 build
    Anyone got any suggestions to repair hull cracks?
    1991 550sx stock
    1989 x2 stock
    Oct 2015
    Michigan
    Re: js550/650 build
    IMG_1732.JPG Started sanding down the the hull. Also thank you to still standing, jafaboy and dpast08 for the conversion/650 stuff. I still need 650 bolts to mount to the engine plate.
    1991 550sx stock
    1989 x2 stock
    Oct 2015
    Michigan
    Re: js550/650 build
    IMG_1787.JPGIMG_1786.JPG installed the conversion plate and set it in the hull to see how it looks. Still have a lot more cosmetic work to do before I can put it back together. Slowly coming together.
    1991 550sx stock
    1989 x2 stock
