Results 11 to 13 of 13
    Jul 2011
    Dearborn, Michigan
    Re: 02 GTX-DI stator voltage low/non existant
    You rock! Thank you. I wanted to verify with the masters here.
    Resident Guru Bionic racing's Avatar
    Idaho/California
    Off electrical problem , since that ski had a new engine installed make sure to verify oil flows freely through filter from tank , that is one main reason for engine failure on those DIs , most people don't check the simple things when swapping an engine that has oil injection
    Jul 2011
    Dearborn, Michigan
    Thank you, I will!
