    Sep 2017
    Newyork
    Inexpensive, but effective 951 mods
    So i sent my top end out to be measured, so i could order a top end kit. Kit is on the way and cylinders waiting. While im building a fresh engine, im curious what are some inexpensive but effective mods i can throw on this engine while im rebuilding it? I dont want to shorten the life of engine by going too extreme. I saw a couple performance parts for sale in classifieds and wondering if i should grab them?
    Illinois
    Re: Inexpensive, but effective 951 mods
    Depends how far you want to go and your goals. The 951 is already a very capable engine and will be plenty fun for most when dialed in perfectly
    Mild head, prop, intake grate, sponons = nice rec ski that doesn't suck gas
    Add a moderately aggressive pip to the above and flame arrestors, +rejet = little more finicky to dial in, sucks more gas, nice pull through the rpm range.
    Past that a more aggressive head/pipe is probably going to start effecting the lifespan of the engine due to higher rpm and you'll need mods to support those RPMs
    Its a slippery slope
    The 951 responds really well to a bump in compression. You can have the stock head milled about .020 thou. Also put on a nice intake grate and impeller.
    Sep 2017
    Newyork
    Sweet. Ill drop the head off to my machinist.
    Sep 2017
    Newyork
    What brand intake grate should i go with? R&D, Worx, solas?
    Top Dog Benflynn's Avatar
    Aug 2015
    Birmingham
    Get cyls ported
    Any of the winged style intake grates help hookup WAY better than stock. The larger the scoop, the more top end speed you lose. The Worx grate is very popular on the GSX.
