Results 1 to 6 of 6
Thread: 87 650 sx
    Jul 2017
    Michigan
    87 650 sx
    New guy to the stand up world here,
    I just recently purchased a 87 650sx and have a few questions for you guys.
    1) is it possible to do a wider bar set up?
    2) when installing the hydro turf would you just do the base of the ski or the side pads as well? I believe what is on it now is stock it is a black padded side with 3 screw holes on top.
    3) are there cons to running the oil block off plate?
    4) if I do upgrade the bars do I need all new cables and electric too?
    Thanks for your time
    Top Dog bandit88's Avatar
    Green Bay WI
    Re: 87 650 sx
    Quote Originally Posted by Newman13 View Post
    1. Yes, any non straight 7/8 standup bars will fit.
    2. If the sides are in good shape, I would just do the tray.
    3. Only con is you need to mix oil, so no gas and go at marinas and such. Otherwise its highly recommended.
    4. Nope, everything should have enough slack to move over.
    -95 750SXI
    -90 TS650
    -91 300SX
    Top Dog
    Dec 2007
    WI
    Re: 87 650 sx
    a aftermarket handle pole spring or a stock 750 spring is a must
    Mar 2011
    Brooklyn Center, MN
    Re: 87 650 sx
    I have a pole spring at $25 shipped and pay paled
    Jul 2017
    Michigan
    Re: 87 650 sx
    is it possible to do a straight bar? I am from a moto cross background and think the straight bar would be a better feel for me.
    What does the aftermarket handle pole spring help?
    Chicago / Portage, MI
    Re: 87 650 sx
    Yea blowsion has a zero degree bar. That and a set of grips and you'd be good.
    I personally like the jettrim pads, they look fantastic and are a better value for the money in my opinion. I have a build with pics in the individual builds section, you can search by my user name.
    2009 1100 SJ:
    Kawi 1100 build in progress
    2009 SJ MINT:
    1987 WJ650:
    1998 SXI PRO:
    3DR hull mods [TBD]
