stock 98 gp 1200 pop off?
Results 1 to 10 of 16
    Sep 2013
    nc
    I'm working on a 98 1200 with 42 hours. I have checked the pop off on the carbs from that ski all around 72.
    got a set of used carbs today and check one of them and same 72 is this to high?
    Re: stock 98 gp 1200 pop off?
    Yamaha runs a very high stock popoff. If everything is stock it will be fine. If you're modding a bit just go ahead and lower it to 42-45psi.
    Stock N/S & 95 gram spring & call it a day.
    Sep 2013
    nc
    sounds good to me I just wanted to confirm thanks guys
    May 2007
    Serch 65u carb balance mod and do it or they wont work right.
    Myself: I can't believe you don't pass this info along.
    Sep 2013
    nc
    I just wanted these back stock there not skis i plan to keep I put the carbs back on now
    Quote Originally Posted by driftmaster View Post
    I know.......I've had a lot going on lately and i think my brain is scrambled.
    I rebuild 1200 NPV carbs everyday & they run just fine without the balance mod.
    May 2007
    If you would do the balance mod you wouldn't have to rebuild them everyday.
    If you really think this you dont have a clue what your doing.
    Seems like they run just fine unless they hiccup or backfire. Then they crease a checkvalve, run that cylinder lean, and blow up. All the blown 65u that I've torn down to date, all had creased check valves in the carb running the blown cylinder. I wouldnt say it HAS to be done.......but the return mod is good preventative maintenance. I actually just got a pair in that will be getting the mod and i also have a customer that wants his done when i winterize them.
