Kinda disappointed with a heavily modified 750 - Page 4
Page 4 of 5 FirstFirst ... 2345 LastLast
Results 31 to 40 of 42
  1. #31
    Jun 2011
    Norcal
    Re: Kinda disappointed with a heavily modified 750
    a solid 750 engine, with SBN 44 or 46, high comp head, coffman pipe, and large hub hooker will have plenty of power.
    To get more power you would need a FPP. But even a coffman pipe will rip.
    if you are having issues once this setup is achieved then I would guess there is something else going on- possibly ignition.
    - John Kenneth Galbraith
  2. #32
    Dec 2006
    Mesa AZ
    I too was disappointed in my 750 in a 650sx. Bored 1.5mm, 175psi head, dual 40 carbs from SXR, 650 flywheel. Tried a couple different pipes. skat 9-17. Was more then a 650 but still not close to enough. A piped yami 701 would destroy it in acceleration.
  3. #33
    Frequent Poster vocalDyslexic's Avatar
    Jun 2012
    Dallas TX
    I would place a wager on that. My issue was fixed with a hooker impeller, it was slipping the 15.5 badly and once the new exhaust is in and the 650 coffman is off, i would highly doubt a 701 with a pipe will out accelerate this setup.
  4. #34
    We have also had issues with X-2 swaps. Engines run hard in other hulls, and lack power in the X-2.
    I recommend you drill, or change your water box to an aftermarket / free flow. 2" in and out is much better. Should also look at a larger exh hull exit, the stock one is small, and we have had problems with them being even more restricted with sealer / glue. You need a 2" for max power.
    email watcon@watcon.com
    Please visit our web sites
  5. #35
    Dec 2006
    Mesa AZ
    Quote Originally Posted by vocalDyslexic View Post
    I've run other ski's. It lost. Top speed was the same, but they'd get a good 4 hull lengths in front of me or so.
  6. #36
    PWCToday Guru 01GS's Avatar
    WI
    From my understanding the stock hood doesnít flow very well even with a 650. You put a monster 750 in there you likely need more air for it to breath. There are threads about adding airflow. I did something different from what I saw because I donít have hood foam and could get pvc in there easier. You can test my theory by running without a hood and see if it pulls harder if you trust yourself not to sink it. Basically a pvc tube from the center of the hood up top into the hull. Also you can open up the stock inlet more with a dremel. I have a ported small pin with blaster limited chamber, light flywheel, stock keihn carbs, 2Ē waterbox and outlet, 170 psi and it pulls like a freight train. Top end isnít super high with the hooker 10/16 but I donít care. It probably does close to 48-50 but it gets there instantly. I have a pump stuffer too and it will jump out of the water from its own power at a standstill.
    84 JS550/750 Rhaas pump kit
    88 X2 ported 750
    96 SLTX 1050
  7. #37
    Jun 2012
    Dallas TX
    I thought about that but never came back to it. Probably should open jt up a bit before season. I stopped thinking air intake once i got it all lined out and we determined that a full throttle hit from off idle was spinning the impeller quicker than the impeller could move water, and then on top end it would get to a point and wouldnt rev and further, untill pump came unloaded out of water the accelerate hard for a sec once loaded but then same thing. My conclusion was based on fluid dynamics. Take a automatic transmission torque converter for ex. You have stall and lock up of the stator at a set rpm/pressure range. Its the point where everything becomes 'locked up' and the stator speed is matching the fluid speed and multiplication of force is no longer there. At full throttle we hit the point where the 650 15.5 skat couldnt flow any more water and it was like a engine brake, loading down the engine. Like trying to run on a sand dune. Im sure the compination of the 650 coffman, the stock airflow hood, and the drastically wrong impeller pitch all came togather to make the issue worse. Looking fwd to spring now to see how much more violent the new pipe, new dual 46's, and more airflow will be.
  8. #38
    Mar 2005
    Santa Barbara, Ca.
    On both my PJS 840 Supercylinder X2 and my 1100 X2 I had trouble with insufficent air flow. I popped out the square plugs in the hood and that was enough extra flow to make a huge difference for me. Did some permanant hood mods and all is good. Someone was selling some little air scoops to fit the square holes if you want easy...
  9. #39
    WI
    You are 100% correct that an impeller made for an almost stock 52 hp motor is not going to work for one with close to double the hp. The hooker works well with the power you have.
    These are the 3D printed vents mentioned above.
    [url]https://www.shapeways.com/product/EF8RVDGB6/x2-hood-vents[/
    Here are some pics of what I did. I ran it down to the battery side so if water came in it wouldnít affect the carbs. Also with it being up top facing backwards when you ride I doubt water ever gets in this way.
    88 X2 ported 750
    96 SLTX 1050
  10. #40
    Top Dog jrod928's Avatar
    Mar 2009
    Havasu
    100% hood needs to be opened up to allow airflow, don't believe me ride your ski without the latches and try to open the hood under power.
    As for exhaust i'v run 3 different set ups and they're all fairly equal in power.
    blaster limited is my personal favorite with full 2" exhaust is mandatory!
    c4 chamber current set up good bottom end but not as strong as blaster limited
    coffman with bored headpipe 2-3 inches added to middle of chamber and 2 inch outlet at the stinger hit just as hard as the blaster limited and fit in a lot easier.
    prop 13/18 skat swirl i my prop of choice the stock x2 nozzle might be too big for what prop you got. Dont be afraid to play with nozzle size 82/85 is a good combination to start.
    as far as your jetting goes, the carb screws are only good out to 2 turns, after that the fuel is no longer metered by the jet. look at the taper of the aduster screw. There's plenty of specs on jetting for a single 46 but i don't have the because i'm a fan of dual carbs. sounds like youve got a great base to start off with. Refine the combination then make your judgement from there.
    95 HX 951 Mod Rossier exhaust, MSD TL, BlackJack 48's, Skat 148
    98 XPL limited COffman, 48mm Novi's, Skat pump 148
    91 X2 Mod 805 HPE, COffman Dry Pipe, Pixy and Unicorn dust
