Results 11 to 20 of 28
    Re: 1994 XP - at a loss
    Loose filler tube would not affect fuel delivery. Plugged fuel selector would.
    Frequent Poster Sev1n's Avatar
    Aug 2015
    Lake havasu
    did it ever run right after rebuild???
    Jun 2017
    PA
    Quote Originally Posted by Sev1n View Post
    Not for more than a few minutes. Every time I've taken it down to the water it's given me grief. I think the problem is electrical. I charged the battery, started it on the trailer, and then headed to water. It lit right off once in the water and I'd figure I'd wait to see water happened before I took off. Sure enough it slowly dies out. After that it sounds like the battery is dead. I swapped the battery into my JS550 and sure enough, dead as a door nail. I'm going to go through the tests for the charging system and see what happens.
    Dont forget to check for exhaust restriction.....
    Exhaust hose blistered inside from over heating or bird/mouse nest in outlet or waterbox.
    Jun 2017
    PA
    Thanks Grumpy. I doubled checked that stuff and everything looks good.
    Checked resistance on YELLOW with YELLOW/BLACK of magneto harness and got 1.1 ohms. Manual says it should be between .05 and .6. I'm assuming this means I need to change the magneto.
    Your meter leads are probably making the extra resistance. I would be more worried if either yellow reads to ground. And blk/red to ground should be about 59 ohms.
    Jun 2017
    PA
    You're spot on. My multi-meter should auto-correct for the lead resistance, which is .3, but it doesn't.
    Blk/red to ground reads 153.3 ohms.
    That might be ok, do you have a 5 wire stator? Does either yellow read to ground?
    Jun 2017
    PA
    Yes it's 5 wire and neither yellow read to ground. I have complete spare motor/cdi that I just checked and those readings were almost identical. With that said would it be something inside the CDI?
    Since you have the 5 wire stator i think you also have an ignition amplifier. It could be bad. Pic of your e-box opened up would help.
