Results 1 to 10 of 11
    PWCToday Regular mrwhipper's Avatar
    May 2017
    New Holland
    787 carb vs 787 RFI bottom end
    Hey all. Is the bottom end (including case) the same with a 787 RFI as a 787 carb engine?
    Thanks!
    Re: 787 carb vs 787 RFI bottom end
    Not exactly the same because he RFI has a case cooler. Can the RFI case be run on a carbed ski.......YES.
    Cases can be used for a carb model but crank is different ( front snout) where flywheel mounts.
    May 2017
    New Holland
    Thanks guys. I have a chance to get a 787 bottom end from an RFI cheap and I want to build a back up for my 97 GSX.
    Oohh, i forgot about that. You will need an rfi ring gear also.
    May 2017
    New Holland
    OK. It almost sounding it is not worth it. What do you guys think?
    Sep 2017
    Newyork
    Deff worth it. Ive got a complete (minus head) rfi for sale too. All sensors, injectors, fuel pump, harness etc
    May 2017
    New Holland
    Quote Originally Posted by Chrisx88 View Post
    How mush are you asking?
    Sep 2017
    Newyork
    Check out my for sale thread in this section
    May 2017
    New Holland
    Oh Crap. I am sorry all... I put this thread in the wrong section....
