1050 big bore for 951 SeaDoo
    May 2010
    Virginia
    Looking for the parts to build a 1050 for a 2002 XP for rec use focus on top speed. Any recommendations will be greatly appreciated
    Who supplies the best Top end parts including sleeves
    Also whats the best option for the crank to be reliable, are the aftermarket cranks like Hot Rods ok or is there a better solution.
    I read an article about a case cooler is it worth the added work and cost?
    Thanks,
    JRV
    Sep 2015
    Northern Michigan
    Re: 1050 big bore for 951 SeaDoo
    How much do you want to spend. It can get pricey. Unless you have a lot of the parts, be prepared to wait a while until you can find them. A lot of the builders will still put these together but you have to find the pieces. If you have a 951with a usable cases and cylinder your looking a 3500.00cash in parts to go with it. Then you can assemble it. Head, crank and counter shaft, sleeves and pistons, reeds, spacers, intake, FA's, pipe and a Advent ignition. These are the big ticket items and I am sure I left something out.
    Cypress, TX
    Call Watercraft Magic http://www.watercraftmagic.net/Water...ting_kits.html
    They build 1050 engines...
