Transducer Installation
    Florida
    Hello guys,
    I finally got the depth finder now I need to install to the right place. I saw couple of topic including greenhulk but I couldn't find specifically on fx ho hull.
    Here is the one installed on previous hull of fx ho :
    And this is mine :
    Florida
    Re: Transducer Installation
    I tried one location which is the other side of the screw ( on the other side of the plastic separator) that is shown on the second picture it did not work at all. I am assuming that screw attached to the 2 layer smc
    Florida
    I was able to install the depth finder properly thru the battery with a toggle switch and took out the transducer out from the ski and put it on a bucket of water to see is that functioning or not!
    If I turn on the depth finder while the transducer on the top of water it reads some numbers which is unrealistic like 15F and than goes back 3 dot. I think it is working but I still do not know where to install . What I see around the pump is some kind of plastic layer they added from the factory and it makes harder to find a SMC layer to install on 2014 FX HO. I tried to fit in around the battery cover which has a perfect flat surface in between where the battery tray sits but the transducer little bigger to fit on this tiny flat surface so it does not sit perfectly.
    I looked this place from the back draining plug of the jet ski while using my work lights in the hull. But I can not find the right place to put in yet!
