Results 1 to 8 of 8
    Sep 2008
    New Jersey
    07 GP1300R - Power Valve OR Non Power Valve?
    Stupid question...I just bought an 07 GP1300R and it has the D plate but no temp sensor chip so I beeps at you! I am going to buy the chip from Riva but wanted to know how to tell if I have the "power valve" or "non power valve" motor.
    May 2011
    miami
    Re: 07 GP1300R - Power Valve OR Non Power Valve?
    Post a pic of the exhaust manifold. The '07 should be a Non-power valve.
    Mar 2007
    Is Everything!
    non PV.
    you should read up on his a bit as the chip sold commonly doesn't work on the 1300 as was the case for me. I had to make my own with greater resistance.
    Sep 2008
    New Jersey
    I have been doing some reading on the chip and did see that some people had issues with the chip not working on the 07-08's...I called Riva today and they told me that their chip does work so I was gonna give it a shot
    Mar 2007
    Is Everything!
    Theirs didnt work for me, alarm sounded almost immediately. Do you actually believe they would tell you anything different? Go buy a few different value resistors now so you have them on hand and don't waste a day on the water in the event you experience the issues that many others have. They are cheap and will insure your day is not wasted.
    Good luck.
    Sep 2008
    New Jersey
    what do I have to do with them?
    Mar 2007
    Is Everything!
    Determine which one you need (mine ended up being 2k) and jump it across where the old sensor/chip would plug in. Lots of documentation states 2.2K up to 10K
    Sep 2008
    New Jersey
    so just plug one end of the resister into the sensor plug and bend it over and plug the other end into the other side of the plug?
