Thread: Rfi fuel pump
    Aug 2017
    PGH PA
    Rfi fuel pump
    Where does the signal originate that turns pump on? Fuel pump energizes when key is plugged in, starts, runs fine, dies of low fuel pressure, 4 beeps later pump pressures up and cycle continues. Replaced pump regulator with little effect. (2004 3D) THANKS
    Re: Rfi fuel pump
    The throttle solenoid and fuel pump are operated directly from the VCM. The injector pulse comes from the MPEM.
    Aug 2017
    PGH PA
    Re: Rfi fuel pump
    THANKS, but what if anything is monitoring fuel line pressure? Since the pressure is being regulated at pump, could the pump continuously operate bleeding excess fuel in tank? Is there a sensor in throttle solenoid? THANKS again
    Re: Rfi fuel pump
    Nothing, most fuel injection systems dont "watch" fuel pressure. This is why we need to check fuel pressure manually. On the rfi there is no port for that. Since its a low pressure system i usually tee one into the supply line.
    Yes, if something comes loose or the internal bypass in the pump goes bad it could run and run just dumping fuel back inside the tank.
    Aug 2017
    PGH PA
    Re: Rfi fuel pump
    Replaced VCM with new unit, but still has same issue of initial fuel pump energize, starts runs fine until out of fuel, motor stops with 1 long beep. I'm tempted to hard wire fuel pump and mount toggle switch some where handy for lack of RFI knowledge. I HOPE that thE 3D 2004 RFI runs the fuel pump constantly when key is on anyway? THANKS
