Page 3 of 3 FirstFirst 123
Results 21 to 27 of 27
    May 2017
    stockholm
    Re: 2002 ultra 150 dies after 10 sec
    Another thing a remembered.
    When I sealed the crankcase I didn't put 20ml of oil in the rear balancer room. Could this be the issue? And can I inject those 20ml through the rear oil check valve afterwards? Or do I need to split the crankcase for that? (I did remember the 200ml in the magneto case)
    I dont think it could cause an issue this quickly, especially since e erything back there still gets some oil. Yes, you can inject it through the checkvalve. I use a livestock syringe with a piece of tubing attached.
    Nov 2011
    CT
    Just open the cover on the rear bearing for the balancer and pour right in
    Sent from my SM-G935V using Tapatalk
    May 2017
    stockholm
    thanks!
    So what else could cause this problem?
    I've ordered new spark plugs, but I doubt it will make any change, just want to take it out of the equation.
    What else can I check?
    Aug 2010
    Australia
    are the plug leads on the right plugs ??????
    modded X2 650
    Originally Posted by hyosung
    May 2017
    stockholm
    I believe so, the shortest to the closest and the longest to the one most far away. How else can I check if they are right?
    May 2017
    stockholm
    Could it be the pilot screw on the carbs?
    I can see the screw heads and I'm definitely not the first to tamper with them as they have worn marks. But they don't really explain the low top end...
