Page 3 of 7 FirstFirst 12345 ... LastLast
Results 21 to 30 of 63
    PWCToday Regular Case1's Avatar
    May 2017
    Gun Barrel City, TX
    Re: 96 XP Engine Rebuild and Carb Rebuild problems
    I haven't tried it in the reserve position, just the main. I will do that tomorrow though. It will rev out of the water but it won't rev in the water, it just dies and yes it just dies when I try to pull the choke out a bit and try to rev it.
    If it also dies out in the reserve position pull the plugs immediately and see if there are water droplets on the electrode.
    May 2017
    Gun Barrel City, TX
    I will definitely do that. If there is does that mean water in the gas?
    May 2017
    Gun Barrel City, TX
    While rebuilding the carbs the first time I didn't take the low and high adjustment needles out and clean them nor the jet. I did that today and you could tell that there was a bit of blockage
    in the orifices. I get them all cleaned and put back together then onto the pop off pressure test. It popped about 30, but what was strange is that there was air coming out of the side of the fuel pump
    also. That is not normal correct? Keep in mind I ordered the cheapy rebuild kits for $15.00 a piece off eBay.
    Do yourself a favor & get Genuine Mikuni kits.
    The gasket should keep the pump side sealed up. You sure you got all the old gasket material off the pump cover? 30 psi should be just fine. Some blockage in the low speed circuit would definately cause your symptoms. I smear thick tacky grease on the adjuster threads before i stick them back in to keep them airtight.
    May 2017
    Gun Barrel City, TX
    GOG, these were the ones I bought...trash eh?
    http://www.ebay.com/itm/Sea-Doo-Carb...72.m2749.l2649
    Where is the best place to get Genuine ones?
    May 2017
    Gun Barrel City, TX
    Myself, you can feel the air coming out a lot and I am sure I got the gaskets in the right order. Is there a diagram somewhere of the proper order of the gaskets for my carbs? This kit came with a lot of extra ones.
  9. #29
    Quote Originally Posted by Case1 View Post
    Junk $15 really ???
  10. #30
    Google mikuni sbn exploded and youll find the diagrams. I've used literally hundreds of aftermarket carb kits with no issues but i stay away from the no name ones. Jetlyne, Winderosa, and WSM have all worked fine for me.
