Results 1 to 10 of 12
    Feb 2016
    Tampa, Florida
    Valve shim measuring onfx140
    The service Manuel doesn't show when and where and to measure the gap on the valve buckets on a fx140 head. The person that tore the motor apart did not lebel where they went so now I have 12 small tiny circle shins that sit on top of the valaves and need to know the process how to measure .. anyone done this?
    Aug 2010
    Australia
    Re: Valve shim measuring onfx140
    some shims have numbers on them ,most of the time they are worn off , a micrometer is the correct tool to measure shims "however most people dont have one in their tool box , a digital vernier caliper will get you a ballpark sizing , with any luck all your shims will be the same size , post back your findings and someone will instruct you on how to do your model engine,
    modded X2 650
    Originally Posted by hyosung
    Feb 2016
    Tampa, Florida
    Luckily the ski only had 24 hours on it when it hydrolocked.. all the numbers are very visable and I have them all laid out.. I just don't know what and how to measure to where each goes at...
    SE CT
    What sizes are they?
    R.I.P. Super Sic
    Aug 2010
    Australia
    measure from the base of the lobe , set up a dial gauge and turn the cam, 0 at the exact base of the lobe, you may have to set up so as you are base lobe facing up then mark with a sharpie so as when you turn down to use feeler gauge to check clearances !
    modded X2 650
    Feb 2016
    Tampa, Florida
    A little more specific .. kinda confused wht you mean... sorry
    SE CT
    Haha.what size are they?
    R.I.P. Super Sic
    Feb 2016
    Tampa, Florida
    There are multiple sizes ranging from 1(172) all the way to 200 but they vary IMG_1488.JPGIMG_1488.JPG
    SE CT
    You need to install them re torque cam and measure the clearance.check it 180 from the peak of cam lobe.
    R.I.P. Super Sic
    Feb 2016
    Tampa, Florida
    I've never done this before, but you are saying install them and then measure.. do you mean torque down the cams and gen measure the gap between the lobes without the shims inside the bucket? And if so what side do you measure ?
