    PWCToday Guru alaski's Avatar
    Apr 2015
    Alaska
    Angry Primer bulb position
    93 650 Yamaha
    What's the relative position of the primer bulb to filter carb etc.?
    I have it after the filter. Can'tseem to get fuel through to the petpenis!
    Not sucking air because nothing at all happens with penis off!
    Jan 2006
    Smoky Mountains TN
    Re: Primer bulb position
    Auto correct is hilarious
    Not sure why you are trying to use primer with knob in off position?
    Find reserve line that runs from fuel tank pick up to on/off/res knob - Cut that line and install you T which will feed your primer.
    Apr 2015
    Alaska
    Thanks Don. lol
    Just using in off position to check for leaks.
