    Sep 2017
    Illinois
    96 700 Yamaha jet ski. Run on a hose?
    Does any one know or have a picture of which side of the ski to hook up a hose to the cooling system? There are two lines running to the back under the seat and I don't which side is the pick up side. I was thinking it would be the one opposite the exhaust side?
    I dream skis Squarenosed's Avatar
    Nov 2007
    Bonita, CA (so cal)
    Re: 96 700 Yamaha jet ski. Run on a hose?
    Normally there's a plug you remove and install a barb for your flush kit to attach to. Where the red arrow is pointing.
    My small fleet...[90 SN SJ ] [90 X2] [90 Jet-n-Cat ]
    Sep 2017
    Illinois
    Thank you so much. I'll check it out.
    PWCToday Guru alaski's Avatar
    Apr 2015
    Alaska
    What does the green arrow indicate I wonder?
    TIA
    Nov 2007
    Bonita, CA (so cal)
    Quote Originally Posted by alaski View Post
    TIA
    Not sure what whoever made this was trying to indicate, just found it on google.
