Cometic vs Gasket Technology vs Winderosa gaskets - Opinions
    PWCToday Newbie 2KPros's Avatar
    Dec 2016
    Lake Hopatcong, NJ
    Can anyone give some opinions on the quality of these 3 brands?
    Re: Cometic vs Gasket Technology vs Winderosa gaskets - Opinions
    I like both the Cometic and Winderosa over the Gasket Technology but have used all with no issues whatsoever. I use Winderosa and WSM the most cause they are inexpensive and readily available.
    Aug 2010
    delavan, wi
    I always go with Cometic. Never had any issues and been using them for years. It's always better to spend more on better gaskets, an air leak can be fatal.
    I know Winderosa carb rebuild kits aren't very good. Never used their gaskets but people always regret saving money on Winderosa carb kits. Not sure about their gaskets though.
    90 Superjet, 98 Polaris Pro 785, 95/92 Kawasaki 750 sxi, 01 Polaris 600 sc xp
