Results 1 to 8 of 8
    central valley
    cylinder bore chatter
    do chatter marks from fresh bore affect the compression on rebuild ? Basically are they acceptable or not, just had 800 cylenders bored .5 over and 1 cylender shows chatter marking. Please advise
    Oct 2013
    funky town
    Re: cylinder bore chatter
    Pictures will help tremendously.
    I'm only here to make you mad
    central valley
    i havent mastered pictures yet I will contact a friend for help. chatter marks encompous area about size of postage stamp,middle of compression area on intake side of cylender. any comments possible?
    Top Dog bandit88's Avatar
    Green Bay WI
    Was the cylinder honed after the bore?
    -95 750SXI
    -90 TS650
    -91 300SX
    central valley
    yes the cylender was honded
    Sometimes the hone leaves chatter marks. It's a non issue.
    central valley
    sounds like judgement call, no simple yes or no answer . if compression is close to even i ok with that, but wonder about wear on rings
    central valley
    thanks for info
