    PWCToday Regular mrwhipper's Avatar
    May 2017
    New Holland
    Swapping Oli Tanks in a 1999 GSX RFI
    Hey all. Swapping the oil tank in my wife's GSX RFI. Do I need to remove the exhaust? If so, can I get away with just removing the expansion chamber?
    Thanks in advance
    Sep 2012
    Napa, Ca.
    Re: Swapping Oli Tanks in a 1999 GSX RFI
    No need to remove the exhaust. The oil tank comes out towards the front of the Seadoo.
    drain all of the oil out of it, disconnect the hoses, disconnect the level sensor, disconnect the 3 straps, then it will slide right out towards the front.
    the oil tanks on these SeaDoo are notorious for failing after about 10+ years. The seam either splits, or the tanks crack somewhere.
    May 2017
    New Holland
    Quote Originally Posted by Napa_Dave View Post
    Great news.
    Yes, that is why I am swapping it out. It is leaking at the seam. I purchased one out of a 96 with no seam. This is my project for today.
    Jun 2004
    DFW- Texas
    But good luck.......much easier to pull the pipe and have room to work IMO.
    16 RXP-X 300
    JS 550 with 650 Conversion
    04 RXP - w/mods - SOLD
    99 GSX Limited #1- SOLD
    99 GSX Limited #2- SOLD
    96 XP- SOLD
    95 XP- SOLD
    94 750sx- w/mods- SOLD
    94 SN Superjet- w/mods- SOLD
    04 Speedster 200 -SOLD
    May 2017
    New Holland
    All done! Changed lines, filter, and tank. Went quite well. Thanks again for you help!
