94xp 657 bogs down after rebuild
    Jun 2017
    PA
    I'm trying to dial this XP in after having the engine rebuilt. Did a complete rebuild on the carbs, including N/S. Pop off was 21 psi. Low speed screws are set to 1 1/4 out. Everything on this is stock. It completely bogs down until it stalls if I give it some throttle. I made it 50 feet, it stalled, and I restarted to idle back to the dock. After I restarted I couldn't give it any gas without it wanting to again just bog down. I'll pull the carbs again to ensure everything looks good but I'm at a loss. What else can I check or where should I start?
    May 2008
    florida
    Re: 94xp 657 bogs down after rebuild
    Start by checking the compression, 150 is Good. Then check fuel routeing & flow. Do you have Old Gas? Then if no results you should check the RV wear & time. Then check the Pulse line for leaking
    as the carb mag fuel pump needs a good push/pull.
    Bills86e
    Illinois
    Compression
    Spark
    Fuel
    Engine needs those three things to run. Check them in that order. Does pulling the choke make it bog more or less? Have your pressure tested the fuel system or checked/replaced the fuel selector valve?
