Results 1 to 10 of 10
    PWCToday Regular ZT4's Avatar
    Jun 2013
    Louisiana
    Buckshot 44 jetting question?
    I have a 96 xp 800 with a factory pipe spec 2 and a buckshot head with 39cc domes and just got some buckshot 44 carbs. I need some help with the the jetting on them. Can someone tell me what the jetting should be. Thanks.
    Dec 2011
    Niceville, FL
    Re: Buckshot 44 jetting question?
    I would start with 125 pilots and 115 mains. Pop off around 15psi. Lows out 1.5 and highs out 1 to 1 1/4.
    Jun 2013
    Louisiana
    ttt
    Top Dog Benflynn's Avatar
    Aug 2015
    Birmingham
    I'd go with matts setting, he has or has had every part ever for a 787, I bet he has owned those carbs, the actual ones in ur hand twice
    Dec 2011
    Niceville, FL
    Yes I've set up Buckshot 44's many times. I started you on the rich side of things to be safe. I've been able to drop the total jetting down to 235 in some cases. Did you have issues with my initial suggestion?
    Jun 2013
    Louisiana
    I didn't try your set up yet I will though. I usually run 4 to 1 or 3 to 2 ratio on my gas.
    4 gallons of 93 to 1 gallon of c12 110 octane.
    Dec 2011
    Niceville, FL
    The extra octane will help ward off detonation if you have aggressive timing, a race pipe, and/or high compression but it does not really affect the carb jetting. I run 93 with heads and race pipes so I have to make sure it has enough fuel and that the timing is under control.
    Jun 2013
    Louisiana
    The only other thing I have is an MSD rev limiter
    Dec 2011
    Niceville, FL
    Quote Originally Posted by ZT4 View Post
    Both the MSD 4255 and the 42581 also advance or retard the initial timing as well as reset the rev limit.
    Jun 2013
    Louisiana
    Well I'm going try your set up
