    Mar 2008
    so cal
    Seadoo 951 revs fast to 6k RPM then 7k right after
    At the beginning of the day it revved up to 7k RPM as it usually does. After a few rides it revved up to 6k then climbs up to the usual 7k rpm a second after. Anyone know what the issue is? It's not the gauge acting up because I can hear the engine at 6k rpm then hear it slightly more at 7k rpm.
    Frequent Poster Keno's Avatar
    Sep 2010
    Kansas
    Re: Seadoo 951 revs fast to 6k RPM then 7k right after
    Heat soak, possibly.
    96 xp - not stock
    RCW Brawler
    Braap!!
    PA
    Carb or DI? I can tell you the DI opens the RAVE valve about 6k. Perhaps slow opening due to leak and you're see the performance delay.
