    Jun 2017
    PA
    94 XP 657 cranks only with the plugs out
    I picked up the above ski for parts and possibly a future project. I wanted to compression test the motor and it'll only turn over with both plugs out. It cranks much slower than it should as well. The battery is good. I sanded the terminals to try and improve the connection but still no dice. I'll double check the cables but is there anything else I should take a look at?
    Re: 94 XP 657 cranks only with the plugs out
    Bad starter
    Jun 2017
    PA
    Thanks Grumpy. I'll pull it and take a look.
    PWCToday Newbie Yscrewu2's Avatar
    Feb 2015
    Illinois
    Unless that battery is brand new don't be positive that it is good it's happened to me more than once try a new battery before you rip apart anything
