    PWCToday Newbie Oskar's Avatar
    Sep 2017
    California
    06 VX110 filter location
    I can't find a thread about this.
    I want to inspect the air filter on the 06 VX110 sport I just bought.
    Where is it located?
    Re: 06 VX110 filter location
    Its inside the black airbox. Right in front of the engine with 2 rubber tubes. Disconnect the one leading to the throttle body and just pull the short one off all together. Then remove zip tie holding fuel hose and wiring. Then 6 phillips screws to pull off lid.
    Sep 2017
    California
    Thanks I'll try that.
    Sep 2017
    California
    Not bad for a 10 year old
    Dont replace it.
    You dont ride in dirt & sand & is a huge source of restriction once it gets wet. Throw it in the garbage & run without it.
