Page 3 of 3 FirstFirst 123
Results 21 to 24 of 24
Thread: Project Outcast
    Sep 2015
    Northern Michigan
    Re: Project Outcast
    some recent photos
    Sep 2015
    Northern Michigan
    Re: Project Outcast
    As you can see in the photos above the through hull hole was not big enough to accept the seadoo driveline bearing support so I hogged it out with a die grinder , Then placed a 1 and 1/4 inch pvc tube in there with three inches extending into the motor compartment through to the pump tunnel . Then took some microfiber thicked epoxy and made a peanut butter consistency blend and faired (smoothed) the transition points and after about twenty minutes layed some 10 oz S-Glass squares inside the tray area to seal and reinforce the bond lines. worked out good will be adding more layers later. So far the layups total 50 oz of S-glass, I will be adding another 30 oz . At that point I will remove the tool (old pump tunnel from the outside and see how it is strength wise and go from there. was working on a 90 degree day and had to ice even the smallest amounts of mixed resin to keep it from going off.
    PWCToday Guru veedubs's Avatar
    Jul 2012
    Atlanta Georgia
    Re: Project Outcast
    Cool project. I'm intrigued by these 951 engines.
    Sep 2015
    Northern Michigan
    Re: Project Outcast
    Quote Originally Posted by veedubs View Post
    You and me both. The search for powa continues.
