    Sep 2008
    The flakka capitol of Florida
    Protocol for blown sc washer
    07 rxp, has a blown sc; owner says one washer is missing.
    How much damage we looking at? Engine is still running but down on power.
    Re: Protocol for blown sc washer
    this is quite common. there are lots of detailed writeups on greenhulk.. Basically those washer bits are all through the motor.. So everything has to be completely disassembled, cleaned and inspected for damage. then put back together..
    Yep, ive got a 255hp apart right now. Little bits of metal everywhere, ruined bearings, ruined oil pumps, basically a light overhaul.
    This be true
    Sep 2008
    Ok, engine has to come apart no ifs ands or buts. Got it
