    Oct 2016
    Massachusetts
    1991 superjet 701 swap b pipe
    Can I put a newer b pipe, like for a 96-17, in my 91 superjet. I'm getting a junk wetjet kraze, and am planning to put a b pipe on it. Also can I use it on a 61x case?
    Top Dog Benflynn's Avatar
    Aug 2015
    Birmingham
    Re: 1991 superjet 701 swap b pipe
    They are the same
    Oct 2016
    Massachusetts
    So if I bought one off blowsion that says 96-17 I'd be ok even though I have a 91?
    Michigan
    The pipe chamber is different for SN and RN SJ's. I have a Factory B pipe in my RN and my SN. The head pipes are the same and from what I've read and been told the newer Limited and Modified chamber will fit nicely in the SN hull.
    Feb 2013
    NorCal
    I run a newer style bpipe in my 91 SN.. The difference is the SN bpipes are made for the 650cc engine. The new bpipes are for 701cc+ It also wont hurt to run a 701cc bpipe on your 650cc engine.
