Results 1 to 10 of 10
    I dream skis scottie3355's Avatar
    Oct 2005
    North Dakota
    Black Magic Intake Grates?
    Have these intake grates, they look like they have similar bolt pattern so they fit the same ski but are different styles (open vs deep scoop).
    Has anyone ever seen these or have any idea on what ski/model they would fit? I did see a black magic intake grate on ebay and i've only seen black magic products for Tigershark so I assume they are for a Tigershark but have not idea.
    Any ideas would be great.
    Thanks!!
    Pics attached
    Jun 2004
    Lansing, MI
    Re: Black Magic Intake Grates?
    The older Sea Doo's have a similar bolt pattern too. I have never tried a Black Magic intake grate and have no idea if they would fit a Tigershark. Is there any part number markings on them?
    98' Sea Doo SPX Mint
    96' Sea Doo HX Mint
    95' Sea Doo XP800 Mint
    My Jet Ski videos below.
    Cottage Grove, MN
    Black magic was a sub division of Arctic cat from the mid 1980s through the early 2000s. They made "factory" performance accessories for cat's sleds, ATVs, and tigersharks specifically. No, not a single black magic part will fit any other brand/vehicles except cats obviously. Those look like they could fit the older cast pump housings. Skis like the 94-96 Montego, 94-95 Daytona, 94-95 Monte Carlo ect.
    Own:
    99' TS770R
    98' TS1000R
    97' Daytona 1000
    Owned:
    94' Montego (my first) sold
    95' Daytona sold
    95' Daytona parted out
    95' Barracuda sold
    96' Montego sold
    96' Monte Carlo 900 sold
    Oct 2005
    North Dakota
    Part numbers are 33-0293 and 33-0289
    I have pretty much checked every Tigershark imaginable and non have that bolt pattern...
    Cottage Grove, MN
    Did you try the 95 montecarlo 900? That one had it's own pump for that one year and is one of the rarest pumps to come by
    Own:
    99' TS770R
    98' TS1000R
    97' Daytona 1000
    Owned:
    95' Daytona sold
    95' Barracuda sold
    96' Montego sold
    PWCToday Newbie Whossharkbait's Avatar
    Jul 2015
    Nebraska
    They are 97 possibly 98 Daytona 770 and 1000 intake grates
    99 Tsr 770: gps 59.3, kawi 1100 limited motor, dried out stock pipe, mikuni 44s, Ada head 145psi, 148 mm pump.
    94 barracuda custom: 770 limited motor, 2* static advance, vforce delta reeds, milled head 165psi, molded pump inlet grafted on with 146 mm pump.
    Cottage Grove, MN
    I thought about that too but they are missing the huge scoop for the front side of the impeller. I can't remember the name of it so that's my discription of it.
    Own:
    99' TS770R
    98' TS1000R
    97' Daytona 1000
    Owned:
    95' Daytona sold
    95' Barracuda sold
    96' Montego sold
    Jul 2015
    Nebraska
    Your right, but that's the only grate that uses a single bolt up front. Unless they are one off and used a shoe from a newer ski
    Oct 2005
    North Dakota
    I'm pretty sure those grates have 4 bolts up front instead of just two... the search continues!
    Jul 2015
    Nebraska
    I'm going to say those are probably for team skis not production skis.
