Running Pre-mix in oil injection ski
    PWCToday Guru alexk243's Avatar
    Jun 2007
    Crystal Lake, IL
    Is it bad to run premix in an oil injected ski if the oil tank is empty but there is no oil block off installed?
    Sent from my Nexus 5 using Tapatalk
    2007 Kawasaki 800 SXR
    1984 Kawasaki JS550
    PWCToday.com Is My Home Away From Home Maulin Marto's Avatar
    Sep 2009
    IL.
    Re: Running Pre-mix in oil injection ski
    Depends on the machine. What make and model?
    2010 UWP Masters National Champion, Governor's Cup / 2013 GLWC Masters #1/2013 GLWC Ski Slalom #1/2013 Vet Open #2
    2009 & 2010 Vet Open Great lakes Champion /2009 GLWC Masters #1 2009 Sport spec #1 /GLWC 2011 #3 Vet Open
    ​CBD OIL ANYONE? http://53CBD.COM
    Ebay Store Link> http://www.ebaystores.com/unclemartospartsstore
    Jun 2007
    Crystal Lake, IL
    1996 Yamaha Waveblaster 1, stock engine.
    Previous owner had been using premix, but left the oil tank intact and attached.
    1984 Kawasaki JS550
    Sep 2009
    IL.
    Won't really hurt it but if your going to run pre-mix you should just buy the $10 block off plate and pull the pump at least. My opinion.
    Jun 2007
    Crystal Lake, IL
    Quote Originally Posted by Maulin Marto View Post
    Yeah I did, was just waiting for it to arrive and I wanted to go ride...
    1984 Kawasaki JS550
    Resident Guru bored&stroked's Avatar
    Dec 2006
    Mesa AZ
    No won't hurt anything.
    '90 Superjet: ported 760, dual 44's, B pipe, ADA head 190psi, TDR waterbox, hooker 10-16, sponsons. Wife's ride
    '94 Suuuperjet: 84mm 61x, ported, protec pipe, H2o designs waterbox, Newmiller head 175psi w/girdle, protec ride plate, Protec mod'd cdi, UMI grate, RN pole -4", rev footholds, solas prop, sweet green turf+wrap.
    '95 Raider 701: Fiberglass not SMC, Hydrotrailer hitch, ugly purple and yellow everywhere.
    Quote Originally Posted by alexk243 View Post
    Assuming the oil injection pump is still connected?
    Running the engine without oil in the tank will wear out (ruin) the pump.
    The oil injection pump depends on the injector oil to lubricate the pump. Without
    the oil, the pump will run dry and wear out.
    Jun 2007
    Crystal Lake, IL
    Quote Originally Posted by wmazz View Post
    The plan is to remove (removed already) the pump anyways then I am not sure it matters
    1984 Kawasaki JS550
