2006 STX 15F New to me Water in Cylinders not it oil - Page 2
Results 11 to 16 of 16
    Aug 2017
    seattle
    Re: 2006 STX 15F New to me Water in Cylinders not it oil
    where do I find the upper one ? and how much will it be
    Aug 2017
    seattle
    so this is the exhaust manifold we are talking about
    Aug 2017
    seattle
    Super strange!!! took it to the lake today and it died within 20 minutes and didnt think it would restart.... it ran great before and after mid 50s
    I headed for the trailer and shut it off and acted so hard to turn over.
    I put it on trailer took it out of water and pulled plugs ....... turned over great NO WATER out of any hole!
    put plugs in and wouldnt turn over..... im home now and freah charged battery was 75% so its charging again soon as it is at 100 ill try starting
    What the heck?
    Dec 2005
    Page, Az
    I recommend you check the jet pump for a bad brg. I had this happen to some 08 Kawasaki stx15f rentals, and if you continue to run it you will take the crank and cases out of the engine.. hopefully this is not the issue but if it is your engine is probably toast
    Dec 2005
    Page, Az
    check your dipstick to see if the oil is turning black
    Aug 2017
    seattle
    this was a rental so lots of hours on it..... the oil is not BLACK its still in pretty good shape..... I will check the bearing
