    PWCToday Newbie Yamaha runner's Avatar
    Mar 2012
    Stevens point, Wisconsin
    1994 Seadoo Gtx runs on trailer fine, but doesnt run in the water
    Hey guys, I have a 1994 seadoo gtx that runs fine on the trailer but the when i put it on the water , it runs for about 5 seconds and bogs down. I tried staring it before putting it in the water and then backing the trailer down and the second it hits the water it dies. The engine was rebuild this year and a bunch of other stuff was replace, has 120 psi of compression on both cylinders that was with a weaker battery , my high speed is set between 0 and 3/8, and my low speed at 1 1/4, spark is good, i checked my waterbox and nothing is cracked or loose, i dont smell any exhaust leaks. I saw on another forum that the 1995 gtx or xp has a faulty hose going from the wayerbox to the exhaust outlet that would collaspe in water and flood the engine out with exhaust gas. if anyone would help that would be awesome trying to get it done before a free ride
    May 2008
    florida
    Re: 1994 Seadoo Gtx runs on trailer fine, but doesnt run in the water
    Your 657cc carburetors need rebuilt. 95's have a very different engine set-up. I diagnose this as Too much Air - Not enough gas.
    May 2009
    South Carolina
    Compression on a 657 on a calibrated compression gauge should be 150+ should run OK down to about 135 if balanced. Who did the carbs and are you sure they are correct? Do you know the history of the ski that would help us with troubleshooting your problem E.G. was it running good before? , what was done during the rebuild?
    Think Big!!
    Jun 2004
    DFW- Texas
    ^ I was about to say, that is low compression. Should be 150. I would rebuild carbs with genuine kits, not the cheap e bay junk. Lastly check for spark on both plugs. I had a xp that drove me nuts and ended up being a bad plug boot.
    16 RXP-X 300
    JS 550 with 650 Conversion
    04 RXP - w/mods - SOLD
    99 GSX Limited #1- SOLD
    99 GSX Limited #2- SOLD
    96 XP- SOLD
    95 XP- SOLD
    94 750sx- w/mods- SOLD
    94 SN Superjet- w/mods- SOLD
    04 Speedster 200 -SOLD
