Results 11 to 20 of 25
    PWCToday Guru E350's Avatar
    Jul 2015
    Sacramento Delta, CA
    Re: Race mods: Set back pump, front fill, tubbies, trim, etc.
    Quote Originally Posted by waterhappy View Post
    Some guys out as sxr chines on the X2 but it does add lift on the ski making it twitchy on the nose. Every mod changed something else. The best is a pump fill and tubbies, no real draw back in these. A front fill adds a lot more splash, smother through ruff water but requires a lot more effort to hook a turn so a lot of guys will add length to get more lift in the rear to keep the nose down. You should try to ride one before you change it I'm.
    waterhappy: That sounds like truth to me.
    What is a "pump fill"?
    And while we are at it, if you know, what is a "pump set back"?
    I dream skis waterhappy's Avatar
    Jul 2009
    LHC AZ
    A pump fill is when you put a piece of pvc over the drive shaft exit and fill so the water flows smoother into the pump. A set back pump is when you use a pump shoe that moved the pump (2 inches typically) back from stock position so lengthen the intake area so it handles white wash better. You can set back with a 750/800 pump and this is the time to upgrade to a mag pump. (12 vein instead of 6 and larger inside hub)
    God, family and ski's.
    650sx
    850sxr a/m
    650X2
    Mar 2010
    Down by the river
    I'm wondering if waterhappy is talking about the "driveshaft fill". Here's a how to thread for this that actually has pictures!... basically - where the driveshaft passes through the hull into the front of the pump inlet, there's a recessed area in the hull. guys fill it with fiberglass filler (not bondo) so that the pump inlet has a smooth surface. the stock recess creates a turbulent area in the inlet. There's a stock part from Kawasaki for the sxr or sxi / sxi pro that fits here as well & does this job.
    Mar 2010
    Down by the river
    my bad missed your reply..
    Jul 2015
    spxfanatic: Just read the entire thread you linked. Thanks buddy!
    waterhappy: We have a 650X2. I notice the same ski in your signature. What Mods have you done to your 650X2? I wonder what can really benefit the 650cc engine? Would the pump mod you have mentioned be underpowered by the 650cc, etc.?
    Jul 2009
    LHC AZ
    I haven't updated signature in a long time. I have a three open X2 and a stock race X2. All are pump fill, the stock boat without a lot of power chops ruff water better and runs out better. I haven't tuned it in a while but with a deep loader 150psi stock pipe with a 38 kehin it hits 41mph.
    650sx
    850sxr a/m
    650X2
    Oct 2012
    Belgium
    The tubbies X2Jess makes are known to be the best for racing.
    Here are pics of my X2 and install pics from when I did gwtrujillo's front fill.
    https://www.amazon.com/photos/share/...KmrdlgQGR6f0Ds
    agree , great tubbies
    So what driveshaft and intake grate would you use for a set back pump?
    Jul 2009
    LHC AZ
    Custom order driveshaft, stainless steel sxr Skat-trak welded with a plate to bolt 1/2" longer
    650sx
    850sxr a/m
    650X2
    Top Dog RacerX2's Avatar
    Feb 2010
    Far Away From You
    use stock driveshaft and a long nose impeller same thing jx2 did
    See di46 drink......See di46 drive......Don't be a di46......
