Results 11 to 20 of 20
    Dec 2011
    Niceville, FL
    Re: Fuel issue, I think 95 XP
    Pop off should be up there over 40psi on 95 717's with dual 38mm carbs. 1.2 seats with 80 gram springs. Sorry you found conflicting info.
    Aug 2008
    Boise
    I wonder if the carbs are different between 95 and 96 on a 720. I know there are SBN's and SBNi's
    Jerr
    SeaDoo FAQs
    Kawi FAQs
    88 JS550
    Aug 2017
    Vancouver Island, Canada
    Quote Originally Posted by jerrspud View Post
    I think so, I know they added the dess key in 96 and rave valves (I think) so it wouldn't surprise me. This one has me wondering. I just dropped the popoff down to 20psi as stated in the oem manual from around 50 and it's working waaaaaaaay better
    Jun 2004
    Lansing, MI
    You might want to mention to people in this thread that you are running aftermarket flame arrestors and not the stock air box. In most cases running open air filters requires the pop off pressure to be lowered. I mentioned this in your other thread as well. Glad to here you got it running good.
    98' Sea Doo SPX Mint
    96' Sea Doo HX Mint
    95' Sea Doo XP800 Mint
    My Jet Ski videos below.
    Aug 2017
    Quote Originally Posted by Dan87951 View Post
    Nope, stock air box.
    Aug 2017
    nevermind. my ski is still running like crap, don't listen to me I have no clue what I'm doing!!
    May 2009
    South Carolina
    Just curious have you checked your compression? On this setup with BN-38I you should be popping off above 40. Main jet should be 135 and pilot 67.5 with a 1.2 needle and seat. Stick with it you will find your problem. Some 717s based on their setup run better on BR7ES plugs.
    Think Big!!
    Aug 2017
    Thanks!... Compression is 140 in each cylinder. I ripped it all out and set the pop off around 45. I think this might be a Frankenstki, it says 850 on the outside but the engine is a 717. Also the carbs were set at 1 turn out for the low which is the stock settings for the 800. Carb throat on engine side is 39mm so I'm not sure if it's a bn38i or bn40i. Anyways, popoff is at 45, low is at 1 3/4 turns, high at zero. Seems to run pretty good on the trailer, I'll take it out and see one of these days....... Taking a frustration break... Lol. Appreciate the help hafweightr
    Aug 2008
    Boise
    Quote Originally Posted by Yabadabadoo View Post
    oh.. it's an 800 hull with the wrong motor in it. Now we're making progress. Don't look at 95 specs.. that's the first year of the 720.. are ya positive it's even a 720?
    Jerr
    SeaDoo FAQs
    Kawi FAQs
    88 JS550
    Aug 2017
    Yes, the metal tag on the stator side of engine says so. I replaced the mpem, starter solenoid, and regulator with 717 electronics (the seller fried them with a car jump start). Only original electronics are the coil and stator so I think I'm OK with the electronics???
    When cleaning the carb I can blow through the small jet but can't remove it (stuck but not clogged) and the main jet says 132.5 I think and pretty sure it's a 1.2 needle and seat (very hard to read that small). Since cleaning and adjusting it's running the best that it has yet on trailer, but I haven't water tested it yet as the lake is far away.
    Question, how can I tell the difference between the bn38i and the bn40i? I used my vernier calipers to measure the inner diameter of the carb on the engine side and got 39mm? wtf? If it is a bn40i, would the settings be much different?
    thanks
