96 Polaris slt 780
    Aug 2017
    Texoma
    96 Polaris slt 780
    I have a 96 Polaris SLT 780 -- MFD and Bilge fuses are blown (just purchased this ski) -- Having to remove the battery (which is bolted down, not straps) then removing the 6 allen head bolts, figuring out I also had to remove the 3 bolts holding the electrical box on so be able to see inside of it, it makes me wonder if I can bypass the fuses inside the electrical box, and install waterproof inline fuses outside of the box for easy changing. Has anyone done this? If so, suggestions?
    Aug 2017
    Texoma
    Re: 96 Polaris slt 780
    54 views and no one?
    Frequent Poster nataliator's Avatar
    Oct 2013
    PA
    I have 6 Polaris couches. Never had the bilge fuse blow. I have had the MFD slow blow fuse go a couple times. It is a pain in the ***, but we flood these things regularly and I always found the added protection of keeping the fuse inside the box is worth the hassle.
    87 650sx Red - 38mm 3 jet, Bored intake, Pipe Mod+TS Mani, Quadrafin plate, Thruster Scoop, Skat 16, 7^ bars, Pole Spring, Lanyard/Bilge Button, Finger Throttle
    88 650sx Blue - 40mm, Bored intake, Pipe Mod+TS Mani, Jetlyne plate, WC Superdeep, Skat 13/16, 4^ bars, Pole Spring, Lanyard/Bilge Button, Finger Throttle
