    Aug 2017
    ontario canada
    1995 Waveraider- adding a igntion key or switch to prevent it being stolen
    Hello just picked up a 95 raider with a 100 hours on it. appears to be in nice condition 145 psi in each cylinder
    My question is ( I tried searching) maybe I am not searching properly.)
    is there a way to add an ignition key or a toggle switch inside engine compartment so the ski doesn't get stolen if left at the dock ? if I add a switch that needs closed in addition to the current key. Wondering have people done either of these ideas and if so can you point me in a direction on the parts.
    thanks in advance.
    ryan
    Jul 2011
    Toledo, OH / Manitou Beach, MI
    Re: 1995 Waveraider- adding a igntion key or switch to prevent it being stolen
    They make a lock that goes right over the start stop switch. We have one somewhere at the lake house ill see if i can find. But honestly you would be better off with a cable lock. If someone wants the ski they will tow it away.
    Sent from my SM-N920P using Tapatalk
    Top Dog
    Feb 2013
    NorCal
    What he said^ Or keep a screw driver in it and unhook the ground from the battery.
    Aug 2017
    ontario canada
    thanks guys appreciated
