Engine alignment question. - Page 2
Results 11 to 20 of 20
    Re: Engine alignment question.
    Quote Originally Posted by Firebird! View Post
    Just wanna clarify. If I'm gonna decide to purchase the Cold-Fusion tool - I need to remove the Bearing assembly (3) and Intermediate Housing (6). And the tool installs in lieu of Intermediate housing (6) - correct?
    Sent from my SM-N910T using Tapatalk
    You will remove the #3 midshaft bearing assembly. #6 Housing mount will stay on the hull. If you need to shim, you do so between #6 & the hull.
    email watcon@watcon.com
    Please visit our web sites
    Frequent Poster Firebird!'s Avatar
    Apr 2006
    Lakeland, FL
    Oo - so the tool mounts on top of '6' instead of '3'?
    '99 Yamaha SUV1200
    '02 Kawasaki Ninja ZX6R
    '12 BMW 650i Convertible
    '12 Mercedes GL350 Diesel
    Sold '99 Pontiac Firebird, '02 Ford Explorer Eddie Bauer, '04 Mercedes SL500 '09 GMC Acadia, '14 Acura MDX
    $8 pop-off pressure gauge
    That tool is a steal for $64.00 I have paid much more for much less specialty tools are expensive !
    Apr 2006
    Lakeland, FL
    +$12-14 S/H
    '99 Yamaha SUV1200
    Apr 2006
    Lakeland, FL
    Finally got to it again. Purchased the 'Cold Fusion Driveshaft Alignment Tool - Yamaha' from Blowsion. And another failure - the tool does not fit! The inside diameter of the alignment sleeve is about 18mm and my shaft diameter is about 20mm. I wish there would be a note about it somewhere or somebody told me about it Now- they probably don't even make this tool for my ski since I haven't seen any variations when I was searching for it? What are my options?
    I dream skis sxrchris's Avatar
    Jun 2012
    panama city beach
    Have you tried adjusting the motor mounts? You could probably do it with motor in. Loosen both bolts on each mount and move engine. That's what I would try next.
    Sent from my SAMSUNG-SM-J120A using Tapatalk
    Apr 2006
    Lakeland, FL
    Yes I did - it doesn't move much. If you look at pictures - I need to move it quite a bit. And since I paid for a tool - I was hoping to put it to work
    '99 Yamaha SUV1200
    Apr 2006
    Lakeland, FL
    So, since the Cold Fusion Alignment tool is not available for my ski - would it be safe enough to re-shim intermediate housing to match the engine position?
    '99 Yamaha SUV1200
    Apr 2006
    Lakeland, FL
    Ok, just an update. Got it fixed to the point where I think it should be fine. Here is what I did:
    When I removed the 'Bearing Housing Assembly' to attach the cold-fusion tool just to find that it don't fit, I just attached a piece of wood to the shaft as straight as I could and seen that the shaft is not centered to the engine, so the tool would not do much good there. So, from my understanding, I had to move the engine over or the shaft with intermediate housing over. I decided to move the engine since I didn't wanna mess with the pump and housing. The shims didn't work, because with each added shim to move the engine sideways it moved the engine up also and it reached the top position sooner then it was aligned. So what I did is took the engine bracket off the engine, grind the bolt holes a bit the needed way and secure it back to the engine. It got better, but still wasn't there. So then I removed each engine mount and did the same thing, grind the bolt holes the needed way a bit and put them back. Now I was able to align the engine with the few shims. I don't know why I had to go through all of this, maybe the engine I got from SBT years ago wasn't the same as the original. Anyway this step is done and I can slowly proceed with the assembly now
    Cypress, TX
