Results 1 to 10 of 20
    Frequent Poster Firebird!'s Avatar
    Apr 2006
    Lakeland, FL
    Engine alignment question.
    Hello. I don't seem to be able to align the engine to the bearing housing assembly. It looks like the engine coupling is too far right from the bearing housing coupling.
    2017-08-22_201212_IMG_8958.jpg 2017-08-22_201338_IMG_8959.jpg 2017-08-22_201458_IMG_8961.jpg
    Do I need to re-shim intermediate housing to get it fixed?
    '99 Yamaha SUV1200
    '02 Kawasaki Ninja ZX6R
    '12 BMW 650i Convertible
    '12 Mercedes GL350 Diesel
    Sold '99 Pontiac Firebird, '02 Ford Explorer Eddie Bauer, '04 Mercedes SL500 '09 GMC Acadia, '14 Acura MDX
    $8 pop-off pressure gauge
    Re: Engine alignment question.
    Have you had the pump, and mid shaft out?
    I find them to be WAY off from the factory.....
    We use the Cold Fusion alignment tool. IMO This is the ONLY way to align a Yamaha.
    You need to pull the engine, and mid shaft. You mount the tool to the bulkhead, and align pump until the insert slides onto the shaft and into the plate like butter. This is where you will determine "if" you need shims on the midshaft hosing.
    Last, you shim / move the engine around to get couplers aligned properly.
    Doing it ANY other way, you risk shaft spline, or midshaft damage.
    email watcon@watcon.com
    Please visit our web sites
    Apr 2006
    Lakeland, FL
    I did have pump out years ago, when I replaced impeller and it's housing. I had bearing assembly out now - replaced and rebuild. Intermediate housing were never touched.
    Another tool - my wife gonna kill me!
    Sent from my SM-N910T using Tapatalk
    '99 Yamaha SUV1200
    Top Dog SkiSwede's Avatar
    Dec 2005
    Denver, NC
    The tool is very nice, but I have years and years on skis aligned by eye and feel with no issue. He's not working on a $30k boat here... If the splines look good, just reinstall the midshaft the way it was, and align the engine to it.
    Apr 2006
    Lakeland, FL
    Quote Originally Posted by SkiSwede View Post
    That was kind of my question - how this should be done? I can see how I can move engine up/down, a little bit left to right if using shims only on one side, but I need to move the engine more to the left without increasing the hight, so how can I do that?
    '99 Yamaha SUV1200
    Top Dog orangefinger's Avatar
    May 2006
    Reno,NV
    A question when u set this up to be aligned did you tighten all screws down all the way on your motor mounts ( bedplate to motor mount )?? , and are there any shims on your motor mounts ??
    94 Blaster "KAW 1100cc"
    650 SC
    Apr 2006
    Lakeland, FL
    Quote Originally Posted by orangefinger View Post
    No I didn't tighten the screws, just thread them in the holes to hold the shims. Don't think that tightening would do any major movement if any at all.
    Currently I have 2 shims at the PTO right mount (looking towards the back) to raise engine and move left, but still looks like need to move left more. Just trying to get into the ballpark before more precise alignment.
    '99 Yamaha SUV1200
    Apr 2006
    Lakeland, FL
    Just wanna clarify. If I'm gonna decide to purchase the Cold-Fusion tool - I need to remove the Bearing assembly (3) and Intermediate Housing (6). And the tool installs in lieu of Intermediate housing (6) - correct?
    '99 Yamaha SUV1200
    May 2006
    Reno,NV
    u should tighten them down...u will be surprised.....
    not saying u should not get the tool....
    650 SC
    Apr 2006
    Lakeland, FL
    Ok - will try that tomorrow, when I'll get back home.
    '99 Yamaha SUV1200
