Mikuni 40mm I body carbs issue
    Aug 2017
    Tonawanda NY
    Does anyone know where I could get a throttle valve for the 40mm I body carbs? Mine broke at the screw for the butterfly. Thanks in advance for the help!!
    Apr 2014
    Michigan
    Re: Mikuni 40mm I body carbs issue
    good luck, i ordered 38mm throttle rebuild for a set of i series i have gonna see if i can make something work. finding stock mikuni parts other then gaskets is next to impossible
    Green Bay WI
    Call John at Watcon, he carries throttle shaft rebuilt kits. Tell him what you have and he will get you the right part.
    -95 750SXI
    -92 750SS
    -81 JS440
    Parts for sale HERE
    Apr 2014
    Michigan
    i talked to him last week concerning the same thing. he doesn't have anything.
