MSX 140 with Hi Speed Engine Miss
    PWCToday Regular TLH101's Avatar
    Jun 2016
    Elephant Butte, New mexico
    I got this 2003 MSX 140 for about the price of the trailer, so it may be worth fixing. It runs great on the trailer, but since we don't jetski on trailers, I gotta solve the issue.
    Under load is has a bad miss. I pulled the plugs and they all look to be burning ok. I took this vid today to better show my issue. You can get a good idea of the issue, before the wind noise drowns out the sound. You can also see the RPM variation.
    Video: https://www.youtube.com/watch?v=B9cgOQ7I-MA
    Dec 2006
    Burnet, TX
    Re: MSX 140 with Hi Speed Engine Miss
    Have you checked the jet pump?
    Sent from my SAMSUNG-SM-G891A using Tapatalk
    Dec 2006
    Burnet, TX
    It sounds like it might be hitting the rev limiter and the speed seems low for the engine RPM.
    Dec 2006
    Burnet, TX
    If the pump is in good shape I would say there is some sort of issue with the ficht fuel injection system. This is the same system used on the Polaris Genesis i and Virage txi. There is a load of information on it over on Greenhulk in the Polaris technical section.
    Jul 2017
    MO
    Yup.. i would start here http://polarispwcknowledge.shorturl....t-things-to-do
    Things I would first check include spark, fuel pressure (notorious for fuel pressure problems), and voltage, both stator and the 40 volt side, and TPS (another common problem).
    Sent from my SAMSUNG-SM-G920A using Tapatalk
