96 Waveraider 1100 "hole shot bog"
Results 1 to 6 of 6
    Jul 2017
    NC
    I have owned this waveraider since 2002. It has 205 hours but has been properly winterized each season, always started and ran great until this year. Back in the spring, took it to the lake for daughter to ride. It would turn over but didn't want to start. A quick couple of shots of starting fluid and it fired up and idled great. She took it out but it did not want to accelerate off of idle. She pulled the choke out a little and it took off; as soon as it was up on plane she pushed the choke home. Id continued to act like this for a couple of more rides so I figured the carbs could use a rebuild. I pulled the rack and rebuild all three with new mikuni kits. Miraculously all three filter screens were clean and only number 1 has some greenish coorosion in the needle seat [cleaned it up] and put all back together. It seemed to run a lot better but still bogged a little at take off. Put new fuel and spark plugs in. It sat for a couple of weeks so I took it out this past weekend. UGGHHH, the take off bog is there in a big way. pull the choke a little and off she goes or just feather the throttle a bit until up on plane. it otherwise runs great and top speed is still 62 on the dreamometer.
    Oh and compression is 118,118,118.
    Any ideas???
    Jul 2017
    NC
    Re: 96 Waveraider 1100 "hole shot bog"
    also rebuilt the fuel pump when I did the carbs.
    Did you replace the needle and seats? I always recommend doing so when rebuilding.
    Also check the fuel select switch. We see many problems with these.
    email watcon@watcon.com
    Please visit our web sites
    Jul 2017
    NC
    I did not replace the n/s. 2 looked brand new; 1 had some greenish corrosion but cleaned up nicely. none of the needles had wear rings.
    I did remove and clean the fuel select switch but it did not have any crud or gunk in it.
    Mar 2016
    orlando
    2
    I had this same problem with my raider. I had the carbs rebuilt 3 times. It got a little better each time but the hole shot acceleration didn't go completely until the 3rd rebuild. I finally had it done by a very good waverunner mechanic. Not all carburetor rebuilds are created equal.
    Cypress, TX
    Refer to post number 3.
    The Needle Valves will leak after a few years causing a rich condition at idle.
    Do a pop off pressure test to verify that the Needle Valves are not leaking.
    If they do leak, you might get away with just replacing the Valve O Rings.
    Best to buy new Valves and Needles, as the Needle Tips also wear out.
