Page 3 of 3 FirstFirst 123
Results 21 to 25 of 25
    Aug 2012
    whitby ont canada
    Re: GTX 97 bogs during transition from idle to mid-throttle
    never have I pressure tested carbs together like that, checking passages into the throat is standard for me but complete leak testing and knowing the diaphrams and external gaskets are good is new to me, maybe I have lucky up till now, I will put this to use tomorrow night at the cottage and test Sat morn, pop off tester in hand, Thanks again will let you know Dave
    May 2009
    the 'ville, kentucky
    thanks for that info
    Aug 2012
    whitby ont canada
    Thanks again, both sides of the fuel pump leaking bad, FIXED
    PWCToday Regular goingpwc's Avatar
    Dec 2009
    Utah
    1957Dave,
    I am glad it helped solve your problem.
    PWCToday Newbie JH1200A1's Avatar
    Jun 2011
    South East
    The pop off specs is 23-43. I personally set them to the lower limit and I have had no trouble. I would aim for 25psi.
