Results 11 to 18 of 18
    Top Dog spatera's Avatar
    Jul 2006
    South Ga
    Re: F12x turbo return lines
    I put a 1/8" pipe tee and put the sensor on the end and a gauge on the tee. It runs about 43psi but you'll see it higher when cold.
    03 Honda F12X (my favorite) Red of course
    Used to have:
    98 GP760, 97 GTX Sea Doo, 97 GP1200, 02 Honda F12X, 2-03 Honda F12X, 05 SeaDoo GTX Supercharged
    Need to have:
    F15X
    Frequent Poster banjomaniac's Avatar
    Jul 2009
    nc
    Is that at idle?
    Top Dog west_coaster's Avatar
    Apr 2005
    San Diego CA
    What exactly are you trying to do? If you're just nervous about getting enough oil to the turbo, as long as there is oil coming out of the line and it's not just a little dribble you're fine. Most ball bearing/ceramic turbos have a .040" or similar restriction in the line to prevent too much oil pressure which pushes oil into the compressor side of the turbo and makes a smoky mess in the exhaust pipe. If the engine is running and your not getting a low oil pressure warning, and you've cleaned the turbo screen, you're good.
    05 F-12X
    Jul 2009
    nc
    Well, I'm gonna flush it and put in some fresh oil and call it fixed. Maybe Saturday if it doesn't rain. Thanks for the info.
    Banjomaniac
    Jul 2006
    South Ga
    Yes, that's idle pressure. The only reason I put a gauge on was because when I rebuilt the engine, I wanted to know the pressure.
    Used to have:
    Need to have:
    F15X
    Jul 2009
    nc
    Well I changed out the waste gate and turbo, seems to be running good now. I will try to water test it next weekend or maybe this week but a tropical system is headed our way.
    Banjomaniac
    PWCToday Guru NunoP's Avatar
    Portugal
    I wonder how it would run with your old turbo after all the other repairs
    2004 F12X
    Jul 2009
    nc
    Old turbo is shot, has shaft play.
