Results 1 to 2 of 2
    PWCToday Guru patrickoconnor's Avatar
    May 2012
    Woodstown, NJ
    Rickter FS1 Carbon
    Rickter fs1 - $11000
    Hull has usual beach rash. Guts are extremely clean and have seen salt twice. Calls or texts are preferred. 8562952587
    Rickter FS-1 carbon
    Handle Pole & Steering
    RRP Cast Pole
    RRP Chin Pad
    RRP Steering
    RRP 50mm Riser Fat Bar
    OEM Yamaha Steering Cable
    TBM Throttle
    OEM Yamaha Throttle Cable
    Pump
    Solas 144 Mag Pump w/ Solas SS Wear Ring
    Hooker 9/15
    Wamiltons Trim, Reduction & Steering Nozzle
    OEM Yamaha 61X Midshaft Assembly
    Engine
    JM 61X 82mm 718 Topend
    OEM Yamaha 62T Bottom End
    OEM Yamaha SBN 44
    Aftermarket 62T Single Carb Intake Manifold
    Carbon Reeds
    Cold Fusion Silver Flywheel Cover
    Rhaas Motor Mounts (4)
    Tau Ceti Flame Arrestors (1)
    Jaz 3 Gallon Fuel Tank
    Exhaust
    Factory B-Pipe
    OEM Yamaha RN Waterbox
    Electronics
    MSD Enhancer
    OEM Yamaha 62T Stator
    OEM Yamaha 62T #Zero Lightened Flywheel
    Rule 500 GPH Bilge Pump
    OCD Tidy Bilge Harness
    OCD Bilge Switch
    May 2012
    Woodstown, NJ
    Re: Rickter FS1 Carbon
    Bump
